Old 05-04-2016, 09:23 AM   #5 (permalink)
ConnClark
DieselMiser
ConnClark's Avatar
Das Schlepper Frog - '85 Mercedes Benz 300SD
90 day: 23.23 mpg (US)
Gentoo320 - '04 Mercedes C320 4Matic
90 day: 22.44 mpg (US)
Originally Posted by niky View Post
They're not telling us what fuel is in the system. It may also be likely that the cleaner is an octane booster.
Also, they should have done the air filter and oil separately. As far as many of us know, a clean air filter won't do jack for extra power.
If you look up Redex fuel additive it is a detergent and not an octane booster.
Also a clean air filter will increase power on a gasoline engine because it allows more fuel/air mixture into the cylinders.
