Originally Posted by mcrews
For power it does make a difference
"The simulated clogged filter significantly affected vehicle performance, increasing the time to accelerate from 20 to 80 mph by 0.6 to 1.7 seconds on the three vehicles. The Outlet DP measured for each vehicle was sufficient for setting a common air filter indicator to the “change” or “clogged” position. For each vehicle, the Outlet DP at some point exceeded 5 kPa and showed an increase over the clean filter in excess of 2.5 kPa, a common standard for defining a dirty air filter.5,9–11"
