Originally Posted by Daox
Yeah, the discharge curve of batteries is really not linear. Once they get outside of their normal SOC range, they drop like a brick. Here is a discharge curve for a nimh battery I found here. You went from the red mark on the left to the red mark on the right in those 3 hours.
BTW, what charger/discharger design did you go with? I need to make one too.
Hopefully I didn't cause any damage.. guess well see.
I went with the cheapy dual ebay LED ones. Seems to charge fine (on it's 3rd? charge now?). I ended up buying 2 extras (and have quite a few other parts, fuses diodes fuseholders, etc.), if you need anything. Also have extra trip buttons if you need those. I'm sure I have other stuff as well.
