Old 05-06-2016, 10:36 PM   #64 (permalink)
NoD~
NoD~'s Avatar
Frogger - '00 Honda Insight Gas Only (unHybrid)
90 day: 68.51 mpg (US)
Weekends are great for getting things done!
I got the EPS motor and pinion out. Pinion nut was rough to get out. I bought a 5/8" rod coupling nut that was about 23mm wide and grinded the end down until it fit a 13/16" socket, and muscled the crap out of it out (it was stubborn and leverage sucks in that spot)
Made a nice template by taking paper and rubbing a dirty finger over it... (man, that sounds bad...)
I went to HomeDepot and got a couple shorter bolts and some aluminum to make the cover plate. Used some copper RTV I had available for the gasket seal, and boom! It's done.
Waiting on the the IMA battery to get a good grid charge and I'll get a chance to check it out. Until then, I got plenty of other projects over the weekend on this green machine. Stay Tuned...
ID:	25980   Click image for larger version
ID:	25981   Click image for larger version
The Following 5 Users Say Thank You to NoD~ For This Useful Post:
Daox (05-07-2016), Ecky (05-06-2016), fusion210 (05-10-2016), HyperMileQC (11-01-2022), Joggernot (05-07-2016)
