Old 05-06-2016, 11:05 PM   #65 (permalink)
oil pan 4
The road doesn't conduct electricity very well.
You need to lean how the 7.3 powerstoke injection system works. There is no replacing it with an all mechanical setup.
Gasoline vaporizers do not increase fuel economy.
If vaporizing fuel worked then propane and natural gas engines would see a large fuel economy advantage over gasoline when comparing BTUs/mile.
I ruled out gasoline vaporizing years ago. Don't waste your time. Lean burn and aero mods are the way to go for gasoline.
