Old 05-07-2016, 08:30 AM   #66 (permalink)
cRiPpLe_rOoStEr
You need to lean how the 7.3 powerstoke injection system works. There is no replacing it with an all mechanical setup.
The block used in the 7.3 PowerStroke started as a gasser when International introduced it, then an all-mechanical IDI version appeared before the PowerStroke. There might be some timing provision for an all-mechanical injection pump, be it either camshaft-driven or belt-driven.
