Old 05-07-2016, 11:19 AM   #65 (permalink)
NoD~
NoD~'s Avatar
Frogger - '00 Honda Insight Gas Only (unHybrid)
90 day: 68.51 mpg (US)
Clutch fluid replacement/bleed...
Not pictured, I used a vacuum pump and pulled all the fluid out of the res and replaced a few times. I did 2 full res fulls to flush out the old crap. Getting to the bleed nipple was pretty easy... Just gotta remove the 2 intake snorkels and then hit the 10mm bolt on the throttle guard, pull that off... and it's right there, as pictured.
I went to do the lower motor mount, but the through bolt was impossible. I sprayed it with PB Blaster and will come back to it.
ID:	25983   Click image for larger version
