Originally Posted by rmay635703
Looking at the gap between the former firewall it looks like you could do some "unorthodox" things to add leg room and possibly offset things forward for your rear seat/battery issue.
Good Luck
Thanks for the kind words!
Some of that space will be taken up by newly fabricated ductwork connecting the Toyota Denso a/c unit to the Firebird Dash vents. I will also use some of that area for mounting the electronics that formerly were mounted under the dash of the Prius V donor car.
That being said, the previously very shallow Firebird glove box will probably end up being much deeper.
Bill the Engineer
