Old 05-08-2016, 04:48 PM   #2 (permalink)
NoD~
NoD~'s Avatar
Frogger - '00 Honda Insight Gas Only (unHybrid)
90 day: 68.51 mpg (US)
I've done a few. Make sure to take off the belt and drive it a bit to see how it feels first. If you can drive it that way, you can definitely loop the line. It'll still be a bear to drive at lower MPH though.
Otherwise, hydraulic power steering works about the same on all cars. Pull the lines, crank that wheel left and right a few times to get out as much fluid as you can, then loop the lines. Just loop the line at the rack, not the pinion
The Following User Says Thank You to NoD~ For This Useful Post:
Sunaj (05-11-2016)
