Old 05-10-2016, 09:59 AM   #12 (permalink)
Sunaj
None - '00 Chevy Malibu LS
I cant seem to find a shorter serpentine belt for a 2000 chevy malibu ls. My car uses a single belt for everything if im not mistaken
I plan on deleting the ac system as well, and there seems to be a bypass pulley for this vehicle for that.
Can I do this w/o a bypass pulley?
cant seem to find a shorter belt anywhere, would love to do away with the pulleys altogether but will make it work with a bypass if i can
also, in this video, the which may apply to my car as well, do i simply remove the two hard lines coming from the rack as show in the video and loop them with some silicon hose? Also attached is a routing diagram for my belt. Assuming the power steering and ac pumps will be deleted, i would need a shorter belt to accommodate * preferably*
