Old 05-11-2016, 01:26 AM   #13 (permalink)
freebeard
Anyhow, I'd like to hear your 2 cents.
Are you expecting good results without posting a landscaping plot plan? What are the dimensions of the L? What's on the inside; a sidewalk around a garage?
With what we have to work with, I suggest a brass Rainbird on a 8ft length of 3/4" pipe, possibly at the corner of the garage with a shield to deflect it off the sidewalk. with a pressure reducer and a 270° sweep it will cover the yard. But in wildfire conditions you can knock out the stop and crank it up to wet down an 80ft circle.
Two small ground level 90° sprinklers at the far corners to fill in.
Originally Posted by jamesqf
So what kinds of grasses grow there naturally?
The Good Kind.
