Old 05-12-2016, 09:04 PM   #184 (permalink)
jgatl
Thanks for reposting Bill, I had seen these earlier, but thought with the final placement that things might had changed.
I'm curious how you will connect the Firebird steering column to the steering linkage in the Prius. Also, I read in post 508941 (#90) that you are reusing the Prius speedometer/cluster. Are all the telematics in that one unit?
The Following User Says Thank You to jgatl For This Useful Post:
Bill the Engineer (05-13-2016)
