Old 05-12-2016, 10:13 PM   #75 (permalink)
Ecky
90 day: 39.72 mpg (US)
90 day: 59.69 mpg (US)
Be aware that the Insight has a water jacket in the exhaust manifold. It needs to dump more heat than you'd expect for a 3-cylinder, though you should still be fine in the summer if you're not climbing mountains, I expect.
With a 50% lower and 100% upper, I've seen water temperature approach 105c in cooler months (maybe 40-60f outside) when climbing grades.
