Old 05-15-2016, 10:22 AM   #9 (permalink)
California98Civic
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
You should not need and won't want the fuse holder if you go the route I did. I recommend you consider what Veen and Balto said above too. Most importantly, be prepared to experiment and the experience failure. Don't cut into wires without a schematic for the wiring system and consider how a given wire might serve several systems. For example, when I cut my switch, it also cuts the fuel pump. No problem, since I am cutting the engine. But if you have an alarm or a car-immobilizer security system, it could get dicey. Plan carefully. Get a wiring diagram. Always try a reversible version of the mod before a permanent one.
