Old 05-16-2016, 10:25 AM   #14 (permalink)
California98Civic
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
Originally Posted by Veen View Post
I'm not sure. I haven't really had a chance to study the FIT wiring. I really need to pick up a Haynes manual for the car. I am leaning towards cutting the injector circuit. Do you know how much current generally flows through that circuit?
I am not sure, but if you cut only the ground, that concern is less significant, which is why I chose to do it that way. Try only reversible tests at first. Often the wiring diagrams mislead a little, and we only discover that more components are affected after we have cut a wire. It can be easily repaired, but the wiring aystem in permanently marked, of course.
