Old 05-18-2016, 05:19 PM   #89 (permalink)
elhigh
Master Novice
elhigh's Avatar
Josie - '87 Toyota Pickup
90 day: 29.5 mpg (US)
90 day: 49.47 mpg (US)
If getting screws to bite in XPS foam isn't working, install some drywall anchors. They look like super-fat wood screws, the threads are about 1/8" deep. That should hold pretty good.
Better still: set the anchor, back it out and shoot some Gorilla Glue adhesive into the hole, then set the anchor again. Let the glue cure before installing your screws. That should hold VERY well.
The Following User Says Thank You to elhigh For This Useful Post:
Joggernot (05-19-2016)
