If the shafts support bearings are greased and factory sealed then don't worry about them.
How likely would seizure occur if i just reconnected these two items? the shaft will easily slide out if something isnt holding it in, ( from within the housing- this would be this rotor, and the snap ring on the shaft which ' locks it in place' and prevents the shaft from coming out. Just trying to be extra sure before i do this. snap ring is not pictured
![](https://i.imgsafe.org/9f8a17a.jpg)
