Old 05-19-2016, 08:56 PM   #31 (permalink)
None - '00 Chevy Malibu LS
So then, with all the stuff deleted out the actual pump, should the rotary shaft be greased or lubed with oil? or is that fine to free spin?
Old 05-19-2016, 09:47 PM   #32 (permalink)
If the shafts support bearings are greased and factory sealed then don't worry about them.
Old 05-20-2016, 01:19 AM   #33 (permalink)
How likely would seizure occur if i just reconnected these two items? the shaft will easily slide out if something isnt holding it in, ( from within the housing- this would be this rotor, and the snap ring on the shaft which ' locks it in place' and prevents the shaft from coming out. Just trying to be extra sure before i do this. snap ring is not pictured
Old 05-20-2016, 01:49 AM   #34 (permalink)
The impeller wheel will rub on the sides still.
I thought the bearing were push fit.
Old 05-20-2016, 02:05 AM   #35 (permalink)
just reassembled the pump. the wheel doesnt seem to be turning against anything
