Old 05-20-2016, 01:46 PM   #3 (permalink)
darcane
darcane's Avatar
Originally Posted by Pierrel View Post
Hi guys!
Ive had my ultra gauge for quite some time in different vehicles. Ever since i moved it to my current 2003 Toyota Yaris the Engine load numbers have been way off. Cant seem to get them over 50% even when accelerating hard.
Also, whenever i turn the key off to EOC, the gauge shuts down and takes forever to start again. Ive tried some different start/shut down modes with no luck.
Have anyone got any advice?
Thanks!
When you moved the UG from your other car to the Yaris, did you reset the engine displacement? If it was on a car with a larger displacement and not reset, the engine load could be off.
Which version of the UG do you have? The newer ones have settings for "Power On Detect Mode" and "Power Off Detect Mode". Changing those may solve your issue. I have an older UG, and I just don't worry about it. I use the gauge to give me a repeatable estimate tank-to-tank, but use numbers from the pump and odometer as my actual mpg.
Past Cars:
2001 Civic HX Mods
CTS-V
2003 Silverado Mods
