Originally Posted by 98hxman
I'm sorry about the shorthand. As far as the car I plan for it to be a fun daily driver that even if I drive it hard on occasion will still average 40 plus miles per gallon. I'm not too into the hypermiling but I do enjoy the thought of ecomodding. A little background on myself Im a Master ASE Tech with about 15 years of professional experience in the field and I've been doing this kind of work my entire life. I also hold certification in chassis fabrication and High Performance Engine building and I wanted to apply some of my knowledge into making an economical fun car.
Impressive. You know a lot more than me, but a question is if you set up a higher compression ratio closer to the cr direct injection engines have, won't you have a problem with detonation? The y5 had a knock sensor, so won't the ECU react to detonation by retarding timing and kinda undermining your purpose a little?
