The factory ride height is quite high on that body style Camry. I'm also lowering the car 2 inches so with that and the aftermarket bumper I should be close go the ground but not too close
Originally Posted by aerohead
A single,size-optimized and ducted opening at the forward stagnation point is preferred.
Ground clearance is a big issue.Here are the recommendations which will allow the car to stay in one piece
