Old 05-26-2016, 09:49 AM   #405 (permalink)
LeanMeanDSM
Defeating the EPA's trap!
LeanMeanDSM's Avatar
DSM - '92 eagle talon tsi awd
Team Turbocharged!
The leanest i can go while still being powerful enough to move the car without misfire is 20.5 afr with timing around 45 degrees advanced, that's using a home made plasma ignition and brisk multi gap resistor-less plugs. i looked into the cyclone intake manifold, and it shuts off one runner to a intake valve at low throttle to create a swirl in the head, i would like to try one, i might be able to run leaner still. also i would be interested in learning more about your prechamber plugs.
The Following User Says Thank You to LeanMeanDSM For This Useful Post:
pgfpro (05-26-2016)
