Old 05-27-2016, 12:47 AM   #407 (permalink)
pgfpro
In Lean Burn Mode
pgfpro's Avatar
MisFit Talon - '91 Eagle Talon TSi
Team Turbocharged!
90 day: 63.95 mpg (US)
Warlock - '71 Chevy Camaro
Fe Eclipse - '97 Mitsubishi Eclipse GS
Originally Posted by LeanMeanDSM View Post
The leanest i can go while still being powerful enough to move the car without misfire is 20.5 afr with timing around 45 degrees advanced, that's using a home made plasma ignition and brisk multi gap resistor-less plugs. i looked into the cyclone intake manifold, and it shuts off one runner to a intake valve at low throttle to create a swirl in the head, i would like to try one, i might be able to run leaner still. also i would be interested in learning more about your prechamber plugs.
Are you running meth injection all the time? I would think this would act kinda like a Mahle Jet system in conjunction with your plasma ignition. My thoughts are the H2O could help with the flame kernel?
I was also going to experiment with the cyclone manifold but got side tracked.
If your ever in the area I would love to show my prechamber design.
Pressure Gradient Force
The Positive Side of the Number Line
The Following User Says Thank You to pgfpro For This Useful Post:
LeanMeanDSM (05-28-2016)
