Old 05-28-2016, 02:31 PM   #11 (permalink)
oil pan 4
As far as I can tell HHO doesn't do anything people claim.
The real way to fix this problem is first do a compression check make sure the engine is even good. Set the timing correct. Then put a wide band oxygen sensor on there and get a carb tuning kit and start getting the carb running right.
The Following 2 Users Say Thank You to oil pan 4 For This Useful Post:
ChillyBear (05-30-2016), Xist (05-28-2016)
