Old 06-02-2016, 07:15 PM   #17 (permalink)
debit.servus
Do not run pure bio diesel, any waste oil, vegetable oil or any other nonsense in that 7.3L unless you don't mind replacing a $5,000 set of injectors.
With the 7.3L you picked the absolute worse kind of diesel fuel injection system to experiment with alternative fuels on.
The only other thing besides diesel that can be burned in the 7.3 is jet fuel.
Plus the methanol and lye used to make bio diesel all come from the petrochemical industry, and the 7.3 still needs oil changes and grease.
As long as the solar panel has some kind of working charge controller that is all that matters.
Really? So even micro-filtered waste or veggie oil will clog the injectors? If so, guess I can't run on them.
I know what your saying. Biodiesel needs oil to be made. And Oil Changes and grease need oil. Unlike diesel there is no need to change the oil or lubricate the drivetrain every 400 miles.
