Old 06-07-2016, 05:24 PM   #59 (permalink)
JimIsbell
Honda Insight Driver
The biggest issue I currently have is there is a pretty bad shudder when the engine is under a good load. Its not completely smooth under lean burn either, but a lot smoother. I assume this is an EGR issue and the valve and/or plate or passages need cleaning. under the car. Both rear skirts are there, but the passenger one has a chunk out of the rear corner. Ah yes, and it came with a spare starter, and a full service manual with mechanical and electrical books.
I am not sure what you mean by "shudder" but its a EGR or clogged passages it will have the "herky jerkys" at about 45 mph in 5th gear. The herky jerkys should not bother you except at about 2000 rpm. If you keep it above 2K you wont have a problem.
