Old 06-09-2016, 01:33 AM   #5 (permalink)
redpoint5
90 day: 38.47 mpg (US)
I've heard it will take several hundred PSI to blow out even the cheapest of tires. I don't think it matters much what the rating is when it comes to running higher pressures. In fact, over-inflation should improve the speed rating of a tire.
A cheap suspension modification is to chop the coils to lower the ride height. All you need is a spring compressor and a hacksaw right?
