Old 06-09-2016, 10:51 AM   #8 (permalink)
HybridGates
I've heard it will take several hundred PSI to blow out even the cheapest of tires. I don't think it matters much what the rating is when it comes to running higher pressures. In fact, over-inflation should improve the speed rating of a tire.
A cheap suspension modification is to chop the coils to lower the ride height. All you need is a spring compressor and a hacksaw right?
Aside from fear mongering, the only data I have seen is that low pressure causes blowouts like rim contact, which actually begins at 25 or 28 psi which is the danger level. personally I think going even 32 psi is to low in that respect, to which 40 to 55 psi is optimal.
Im not trying to lower the suspension, im trying to make it more comfortable like air suspension.
