Whats going on jedi sol just joined these forums and am doing mods to my car now to improve aerodynamics to get a few better mpg's out of her. read your previous posts about having to source your underbody aero trays from japan...
Well good news haha you don't! I'll post up the link for the parts numbers a little bit later on but the underbody aero panels from the crosstrek fir our cars just fine ... need to trim 3 5/8" strips off each side to make a groove that fits directly underneath the stock plastic side skirts. very easy mos to do.. bought both the left and right side panels directly from the subaru dealership who special ordered them for me for $137 including all the under body pop clips for them and the bolts. ill post some pics up later on my project thread for you to check out once off work but with these.. there is zero worry of the panels ever coming off just sprayed each threaded hole with some rubberized paint and the bolt heads once it was mounted to help weatherize everything and its good to go.
Reason: typo
