Old 06-27-2016, 02:56 PM   #20 (permalink)
RustyLugNut
You don't need the compression step.
Originally Posted by ctmaybury@yahoo.com View Post
Use lots of big solar cells at home for the electrolysis and a high pressure commpressor to store the h and the o then use them in a car or truck for water vapor emissions. The whole setup would be fun and expensive to make, but would never pay for itself. Using the charging system in your car to run one is a joke. Water is made of h and o, but it's like ash in that it has already burnt.
Electrolysis is unaffected by pressure, thus, you simply use a version of the Hoffman Apparatus and let the electrolyser compress your O2 and H2 gasses to your desired pressures. There is the issue of the unbalance output of H2 vs O2 so there will be some valving at the least.
