Hydrogen Fuel Injection a Green Upgrade for Thirsty Semi Trucks
For those that are "hho is and will always be a unicorn "
Non-hydrogen injected semi-trucks average between 5 to 6 mpg, whereas the Intel-branded hydrogen trucks average around 6.3 mpg. During a recent trip through California, an Intel hydrogen truck averaged 7.2 mpg representing a significant carbon footprint reduction.
I had a '79 K-20 (3/4t 4×4) with proformance parts Edelbrock carb stock air cleaner with heat riser and a PVC ... ennd of list for smog equipment... I worked at a gas station that had a smog test station. The boss wanted to do an experiment.. High power tune minimal (but leagal except carburetor. ) the truck was running at the bottom of the accepted emissions range. Then we threw all the BS required for a 1/2t CA. Truck (a list of like 20 items) on the engine and then it could pass the visual inspection but the Co and HC were a fail. this was before the NOx dino load cell test..
Summary
A rebuild. 030 over 9.75:1 1979 CARB (California air resources board) compliant 350ci runs dirtier than a hopped up tuned engine...... So we went back to the 1979 Federal, Heavy Duity(over 8501lbs GVWR) emissions equipment list stated previously (3 item list)and a tuned McM Quadra jet (795cfm used on 305ci-454ci) for a clean pass for registration. Then we cleaned up the emissions more by going back to the 1406 Edelbrock carb (600cfm) with the short list.
A way around the GROSS POLLUTER in the future (your RV is already branded GP so this dusn't help you but it will help others ) ...If your questionable do a "pretest" (the results are not sent to CARB) if it passes then apply the test to a Smog Certificate. If it dusen't pass then you save money and your rig is not reported as a GP .
The timing may have to be adjusted outside of parameters to keep the NOx under control.
is your Toyota tested on a Dino? if not
dont worry about NOx its been a decade since I had to dill with CARB (as the NOx test was coming alive. But NOx could only be measured "under load" aka on a dino/load cell . This exempted all fulltime 4wd (Subaru, certain 4×4 trucks ) and over sized vehicles RVs and such from NOx part of the test.
Check and clean your EGR if its sticky it causes problems
Hope this helps
Gumby Stay Flexible
1st gen cummins 91.5 dodge d250 ,HX35W/12/6 QSV
ehxsost manafulld wrap, Aero Tonto
best tank: distance 649gps mi 24.04 mpg 27.011usg
Best mpg :
31.32mpg 100mi 3.193 USG 5/2/20
Former
'83 GMC S-15 Jimmy 2door 2wd O/D auto 3.73R&P
'79 Chevy K20 4X4 350ci 400hp msd custom th400 /np205. 7.5-new 14mpg modded befor modding was a thing
87' Hyundai Excel
83 ranger w/87 2.9 L FI2wd auto 18mpg on the floor
04 Mitsubishi Gallant 2.4L auto 26mpg
06 Subaru Forrester XT(WRX PACKAGE) MT AWD Turbocharged 18 plying dirty best of 26mpg@70mph
95Chevy Blazer 4x4 auto 14-18mpg
04 Chevy Blazer 4x4 auto 16-22mpg
