Old 07-01-2016, 08:08 PM   #3 (permalink)
brucepick
OCD Master EcoModder
brucepick's Avatar
Outasight - '00 Honda Insight
Gen-1 Insights
90 day: 54.18 mpg (US)
Can you tell a difference?
I think so. Had two days in a row where FCD showed 73-74 mpg for both commute runs. Before this fix (and after cleaning the EGR passages) I averaged more like 70 mpg.
If the vacuum system leaks, that has to hurt things. At a minimum, there was insufficient vacuum to properly regulate fuel pressure. Plus, it tends to mess up the air/fuel mixture ratios.
Coast long and prosper.
The Following User Says Thank You to brucepick For This Useful Post:
Xist (07-02-2016)
