Old 08-07-2008, 06:39 PM   #22 (permalink)
lovemysan
lovemysan's Avatar
gutless wonder - '02 Saturn sl sohc
90 day: 40.17 mpg (US)
econoburban - '05 chevy surburban 2wd LT
90 day: 19.43 mpg (US)
Originally Posted by 99clipsgst View Post
How do you Do your maintance on your car? like changing the oil? I just put a Front Belly Pan on but I havn't gone all the way back bc of the oil pan and filter.
All the panels can be removed in less than an hour. 15 minutes on a lift. For oil and trans service there are 2 panels 16" square. To change the oil only one panel is removed. I use a small electric drill. Takes about 2 minutes. For a 2 year inspection 50% of the panels come off. I use a private lift and then drive across the street to an inspection station. I also get the alignment checked with the inspection and cry if I hit anything requiring a realignment. The mechanic I've been using actually put most of the panels back on for as a favor. I'm not sure why he only makes $12 on an inspection.
2002 Saturn SL
sohc + 5spd = 50mpg
mod pics see link below
http://s75.photobucket.com/albums/i3...emysan/saturn/
Real men have wheel skirts.
