That was some service done in the military greens. 6months in the Jaeger brigade, I became a APILAS operator for the reserve.
Passed roadway inspection on the 2nd try, failed smog test because I had 3 engine fault codes in the OBDII system.
According to EU roadway laws in Finland, If any fault codes come from the engine, it is seen as "affecting the emissions" and thus fails it. I know I should have unplugged the battery so the codes would've gone away
The ignition box F**ks with me occasionally, missing a spark in cylinder 2 and 3 and thus flashes the engine light and gives the code.
New Igniter box is 50 us. dollars, but i'll probably order and have it in the trunk waiting.
I ain't changing the igniter box before this ******* runs on 3 cylinders or affects fuel economy :P
If you don't make any mistakes in your life,
life itself will be a f*ckup.
With Volvo to Valhalla and back!
