Old 07-12-2016, 02:09 PM   #51 (permalink)
Volvo-driving MachYeen
Fingie's Avatar
Neo Volvo - '98 Volvo S70 10V
90 day: 24.98 mpg (US)
That was some service done in the military greens. 6months in the Jaeger brigade, I became a APILAS operator for the reserve.
Passed roadway inspection on the 2nd try, failed smog test because I had 3 engine fault codes in the OBDII system.
According to EU roadway laws in Finland, If any fault codes come from the engine, it is seen as "affecting the emissions" and thus fails it. I know I should have unplugged the battery so the codes would've gone away The ignition box F**ks with me occasionally, missing a spark in cylinder 2 and 3 and thus flashes the engine light and gives the code.
New Igniter box is 50 us. dollars, but i'll probably order and have it in the trunk waiting.
I ain't changing the igniter box before this ******* runs on 3 cylinders or affects fuel economy :P
If you don't make any mistakes in your life,
life itself will be a f*ckup.
With Volvo to Valhalla and back!
Old 07-13-2016, 04:43 AM   #52 (permalink)
gumby79's Avatar
little jona - '91 Dodge D 250 first gen cummins LE
Team Streamliner
90 day: 23.4 mpg (US)
Little Jona airo modded - '91 Dodge RAM 3/4 TON D 250 2×4 AUTO
Pickups
The Salted Hound Jenny. - '87 Dodge Ram 50/D-50 5sp 4X4
90 day: 20.24 mpg (US)
Jona Allison aero - '91 Dodge Ram D-250 Le
90 day: 20.76 mpg (US)
4 places the fuel pressure could be going
1 check valve on pump
2 injectors not sealing
3 fuel pressure regulator not holding over time
4 on the ground
Try a hevy doce(2 bottles) of injector cleaner might help
My father inlaw had this problem .he changed injectors and regulator to no avail.
Im shure option 4 isn't the cause but trace the fuel system for pin holes from road debris.
1st gen cummins 91.5 dodge d250 ,HX35W/12/6 QSV
ehxsost manafulld wrap, Aero Tonto
best tank: distance 649gps mi 24.04 mpg 27.011usg
Best mpg : 31.32mpg 100mi 3.193 USG 5/2/20
Former
'83 GMC S-15 Jimmy 2door 2wd O/D auto 3.73R&P
'79 Chevy K20 4X4 350ci 400hp msd custom th400 /np205. 7.5-new 14mpg modded befor modding was a thing
87' Hyundai Excel
83 ranger w/87 2.9 L FI2wd auto 18mpg on the floor
04 Mitsubishi Gallant 2.4L auto 26mpg
06 Subaru Forrester XT(WRX PACKAGE) MT AWD Turbocharged 18 plying dirty best of 26mpg@70mph
95Chevy Blazer 4x4 auto 14-18mpg
04 Chevy Blazer 4x4 auto 16-22mpg
Old 08-10-2016, 08:26 AM   #53 (permalink)
Fingie's Avatar
The problem got fixed by spraying CRC around in the connectors.
Blocked out the upper grille and inflated the tires to 45 PSI.
Planning a lower front dam next.
I was on a job interview today, and I filled up the car (2 clicks). I drove 20miles hwy with two overtakes. drove back and filled up (2 clicks).
Calced 47MPG, and I accelerate full throttle when joining .
The on-board MPG calc is faulty. Have to try some other app.
Last edited by Fingie; 08-10-2016 at 08:28 AM.. Reason: I'm retarded cuz english isn't my language
Old 08-10-2016, 10:35 AM   #54 (permalink)
gumby79's Avatar
Team Streamliner
Pickups
Also check the fuel pressure regulator ,and for minor leaks .my dad just had this problem on a ford 7.3 diesel. It was a faulty sensor on the fuel filter head . So he epoxied the plug hole.
Good work.
Former
87' Hyundai Excel
Old 08-10-2016, 11:12 AM   #55 (permalink)
Fingie's Avatar
I guess I should. Tryin' to find some chloroplast
Old 08-10-2016, 11:15 AM   #56 (permalink)
Engine-Off-Coast
Natalya's Avatar
Red 2000 Insight (2017 through 2019) - '00 Honda Insight 5MT
90 day: 64.72 mpg (US)
Red 2000 Lithium Insight (2020) - '00 Honda Insight LTO
90 day: 71.76 mpg (US)
Do you have any pictures of this thing? Build threads are kinda sad without photos.
The Following User Says Thank You to Natalya For This Useful Post:
Fingie (08-10-2016)
Old 08-10-2016, 11:20 AM   #57 (permalink)
Fingie's Avatar
Here it is. Only visible missing mod is Grille block
Old 08-14-2016, 12:34 PM   #58 (permalink)
Fingie's Avatar
Talking
*happy noises*
Name:	lada consump.png
Old 08-14-2016, 12:35 PM   #59 (permalink)
Fingie's Avatar
how do you attach the consumtion thingy so it updates- or do I really need to make a new sig when I add the log?
Old 08-14-2016, 12:36 PM   #60 (permalink)
Fingie's Avatar
But I am content with the consumption, as I don't really have a light foot.. Yet.
