Old 07-14-2016, 03:16 PM   #67 (permalink)
RustyLugNut
I have done ABA testing, on dynos.
Originally Posted by JRMichler View Post
And I find it funny that, while the HHO true believers refuse to build a system and ABA test it with data according to the principles published on this forum: http://ecomodder.com/forum/showthrea...ery-11445.html, they are perfectly willing to (loudly) insist that HHO is a miracle solution. As long as that solution is implemented by somebody else and without ABA testing.
I've mentioned it before on similar threads. The results range from -2% loss, to nothing to +9% gain. This is for a variety of gasoline engines from the 80s and 90s era. I trust the Superflow technicians who helped with the tests knew their stuff. Diesels of early mechanical designs showed up to a 15% gain in thermal efficiency. There are numerous companies using HHO generators in tractor trailers with some success. Walmart has had units in use for the last few years. I highly doubt a unit that does nothing for economy would continue in use by a company that values every penny.
