Old 07-15-2016, 04:26 PM   #7 (permalink)
oil pan 4
Diesels have a fuel heater to remove filter water and wax build.
Cummins marine does not recommend heating diesel fuel before the fuel injection pump. Diesels operated in the extreme cold have fuel heaters to prevent filter icing and waxing.
With a diesel the injector is screwed into the cylinder head, so the fuel that is injected into the cylinder is the same temperature as the coolant.
mcrews (07-15-2016)
