Old 07-26-2016, 05:36 PM   #10 (permalink)
freebeard
How should I rebuild the engine for Max MPG?
Thanks
OWL
I think you question deserves an answer:
  • Blueprinted for clearances and balance.
  • Wear surfaces cryogenically tempered prior to machining.
  • Exterior surface with heat-rejecting aerospace coatings.
  • Combustion chamber surfaces (head, cylinder valve heads.) coated with ceramic heat-proof coatings.
  • Piston skirts, rings and bearings with low-friction aerospace coatings.
  • Anti-reversionary headers and everything everyone else has suggested.
You can price that all out, calculate the ROI and have a sad.
ChillyBear (07-27-2016)
