Old 07-27-2016, 02:41 PM   #44 (permalink)
t vago
MPGuino Supporter
t vago's Avatar
iNXS - '10 Opel Zafira 111 Anniversary
Suzi - '02 Suzuki Swift GL
Originally Posted by RustyLugNut View Post
Most are found in printed textbooks or behind .edu firewalls.
I do appreciate your persistence in working through this but I have to find links that will be understandable and there are few of those as this is a subject that is not of interest to most and is not reduced to a few Wiki's.
Why not just provide the names of some of these books, then? Give us a chance to at least look at them.
Here, I'll even provide an example (well, two).
I own a copy of "The Internal Combustion Engine in Theory and Practice: Vol. 1: Thermodynamics, Fluid Flow, Performance". I read sections of it from time to time whenever I have some question about improving engine efficiency.
You can find it on Amazon.com here -> https://www.amazon.com/Internal-Comb...dp/0262700263/
I also own a copy of "The Internal-Combustion Engine in Theory and Practice, Vol. 2: Combustion, Fuels, Materials, Design". This is the volume I crack open whenever I want to take a look about how a given engine modification will affect the engine structure itself.
You can also find it on Amazon.com here -> https://www.amazon.com/Internal-Comb...dp/0262700166/
See how simple that was?
The Following User Says Thank You to t vago For This Useful Post:
mcrews (07-27-2016)
