The problem got fixed by spraying CRC around in the connectors.
Blocked out the upper grille and inflated the tires to 45 PSI.
Planning a lower front dam next.
I was on a job interview today, and I filled up the car (2 clicks). I drove 20miles hwy with two overtakes. drove back and filled up (2 clicks).
Calced 47MPG, and I accelerate full throttle when joining
The on-board MPG calc is faulty. Have to try some other app.
If you don't make any mistakes in your life,
life itself will be a f*ckup.
With Volvo to Valhalla and back!
