Old 08-16-2016, 02:42 AM   #14 (permalink)
California98Civic
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
Absolutely do the flush and tests before anything drastic. But...
Back in NYC and NJ driving cabs, we used to crack the hood open so that the summer heat and AC would stress the engine less. The latch of course holds the hood down from flying off. Sometimes I do that now (very rarely).
Do you use the internal air recirculation setting on the vent system? If you do, you'll find you can shut the AC off for 10 or 20 seconds and still be blowing quite cold air. That might be enough for some hills. You could cycle the AC on/off during longer climbs.
Also, easier than adding another radiator fan would be simply to wire a switch to bypass the ECU's control of the OEM radiator fan and turn it on whenever you wish.
