Old 08-19-2016, 12:27 PM   #11 (permalink)
darcane
darcane's Avatar
Originally Posted by CappAttack View Post
Also gonna look at lowering the car a couple inches. Can't go too low though cause I need to clear some pretty rough railroad tracks and speed bumps.
I would go with modest, simple drop springs (nothing adjustable) if that's where you want to go. The exhaust hangs real low on these cars and will scrape on everything. I've got coilovers (Ground Control w/ Koni STR.T shocks/struts) and my exhaust is constantly scraping things. I can't bring it up any higher or I may collapse the rear springs on a hard bump.
Check out my sig for ideas on grill blocking and an air dam.
I've had tank averages in the low 50's back when it was running right. But, I have an HX with a manual.
Hopefully you have better luck with yours than I've had with mine.
Past Cars:
2001 Civic HX Mods
CTS-V
2003 Silverado Mods
