Originally Posted by CappAttack
Missing egr valve connector https://imgur.com/yHDZYMc
Here's a pic of the EGR valve and it's absence of a wire.
Edit: Moved the image from a Google drive link to an Imgur link.
You can see it in the background of this pic:
and here:
Pull the cover off of the spark plug wires and see if it is tucked away under there. There should be two wires coming out of the end of this cover, one is the EGR and the other is coolant temp sensor IIRC.
