Old 08-31-2016, 09:53 PM   #112 (permalink)
California98Civic
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
Originally Posted by pletby View Post
What sort of amperage fuse will I need for my remote located battery? I should have put that in some time ago but life got in the way. It is a safety issue though so I need to address it.
All electrical loads will pass through this fuse so I don't want it to blow upon startup. I'm making a wild guess at 130 amps. I'll see what I can find for current draw on a Civic starter, that should be my highest load.
I'm looking at getting an ANL inline fuse that the stereo crowd uses, they don't seem expensive.
The 1996-1998 Honda FSM rates thestarter motor at 1.0kw or 1.2kw (depending on which you have, I guess. Assuming 12.8 voltage, an ohm's law calculation suggests 78-94 amps, a couple amps higher draw with 12.5 voltage assumed.
pletby (08-31-2016)
