Interesting that Honda uses that engine for natural gas cogeneration and heat.
Its unfortunate that cogeneration systems (which are just a motor and heat exchanger) can't be mass produced and reasonably priced.
If they were priced at the same rate as any other small engine we could produce energy at home more efficiently than the grid with about the same level of reliability. Solar when you have it NG when you don't and need heat.
