Old 08-09-2008, 12:09 AM   #4 (permalink)
Yoshi
SuperMID designer
Yoshi's Avatar
Originally Posted by secmil View Post
-"Level 1" Would mean tapping into one of the 6 apparent leads between the ECU and the ECM.
I don't know this one, but it's not our target, I believe.
-"Level 2" Would mean tapping into one of the six leads from the ECM to the injectors themselves.
Do you mean there are six lines connected to the each injectors?
If so, one of six lines is the target wire.
-"Level 3" (What I hope is it) Would mean tapping into the lead connecting all 6 injectors, the wiring harness (over fuse 229, apparently), and the ECU.
Do you mean this is a single line from the ECU connected to all six injectors?
If so, I think this one is 12V power to injectors.
Yoshi
