Am I understanding correct?
1)
If there's no change in frontal aera the a-b comparison will both be skued the same amount? Making the % of change an acaccurate a-b test. But the actual CdA # would be illegitimate.
Eg. Leave the Headache Rack on for ab cap test (the red part ) because it adds 15*2" of surface. 114*2" aera.79*2'
This shot is from a slightly elevated angle making the increase look larger. The lower bar is below the cab . Ecept in the center its 1/2"T ×6" W above. With ~ 7°pinch for & aft . The 3"W ×1/8"T is dead flat to the air.
The plan is for this to have an air curtain affect. To settle the disturbance from the cab/ cap gap. A less functional more aerodynamic design,has been suggested by many people , would be to eliminate this cab protection feature.
2)the Dodge advertised CdA (have you beenable to locate one yet?not me )compaired to the DARCO naked. Would this yield a value to the amount of skue?
I think the anwser is :
A) there is a variant from tunnel to tunnel so not comparable
3)
The removal of the headache rack (red part ) would alter the %of blockage resulting in a different skue ? A naked test could not be compaired to a headache rack test(different Aera/skue)?
1st gen cummins 91.5 dodge d250 ,HX35W/12/6 QSV
ehxsost manafulld wrap, Aero Tonto
best tank: distance 649gps mi 24.04 mpg 27.011usg
Best mpg :
31.32mpg 100mi 3.193 USG 5/2/20
Former
'83 GMC S-15 Jimmy 2door 2wd O/D auto 3.73R&P
'79 Chevy K20 4X4 350ci 400hp msd custom th400 /np205. 7.5-new 14mpg modded befor modding was a thing
87' Hyundai Excel
83 ranger w/87 2.9 L FI2wd auto 18mpg on the floor
04 Mitsubishi Gallant 2.4L auto 26mpg
06 Subaru Forrester XT(WRX PACKAGE) MT AWD Turbocharged 18 plying dirty best of 26mpg@70mph
95Chevy Blazer 4x4 auto 14-18mpg
04 Chevy Blazer 4x4 auto 16-22mpg
