Originally Posted by samwichse
A power steering delete should make a pretty big difference in that car. And it shouldn't affect your driveability too much since you're mostly highway.
It's a constant, parasitic power-sap.
Speaking of power-saps, if you don't mind the heat, you can always pull the AC compressor, lines, and condenser (maybe evaporator if your system will blow air without it).
You could also pull the passenger air bag assembly since you don't even have a seat there :-P
Sam
Thanks for the reply. I'm going to ask my eco-mechanic about some additional modifications (mainly the stuff you mentioned) after I do phase 1 of the aero mods. I have a few more basic deletes to do as well before I start to tackle removing systems (such as A/C power steering ect).
