Old 09-18-2016, 10:39 AM   #10 (permalink)
California98Civic
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
Your carefulness makes a lot of sense. We have to guard our vehicles and safety always. I move slowly into mods and techniques too. I totally agree with how you are learning all this.
To answer your question, it is low rpm and "high" load I described. In my case, 1500-2000 rpm and 75%-80% load, often 1700-2200 rpm. First and second gear require me to revv higher (I swapped a super-tall 1993 CX/VX trans for my DX trans a few years ago).
I have not done experiments with different load levels. But this is a heavily tested technique if extensive driver experience is a test. You can examine one good example yourself if you look up the PaleCivic on this site. PaleMelanesian drove that car with almost no mods--all hypermiling. He regularly scored 70+ mpg tanks and once, IIRC, a 90 mpg tank. I learned hypermiling, frankly, by imitating him.
The key is how we are using the known dynamics of a gasoline engine. Most gasoline cars will apparently convert fuel into acceleration most efficiently in that roughly 75% load area. At 60% load, at 90% load, at WOT, or whereever, you will use fuel less efficiently. At WOT you might move more quickly because of the amount of fuel you burn, but you'll be bjrning the fuel less effieicently. At light throttle your MPG number may look better during acceleration but the average with your coasting or crusing MPG will be lower because you accelerated less efficiently, over a longer period of time than someone at 75% load.
The Following 2 Users Say Thank You to California98Civic For This Useful Post:
elhigh (09-18-2016), Jared (09-18-2016)
