Originally Posted by Chris D.
I was curious if this has something to do with it..
My FE hasn't been where it usually was when I was in California (Minnesota now)
any incite?
I've never tried it, but there are claims water injection helps FE if this is true I would think that a more moist air would also be of benefit. Cooler temperatures are another thing you are probably faced with in MN as aposed to CA and you always get better mileage in a warmer climate than in a cooler climate. I can usually tell a difference in FE when the outdoor temperature is in the 80's aposed to the mid to upper 90's.
